FME name machine parameter
  • Sep 9, 2024 11:58 AM UTC
  • 121 views
alc33
Forum|alt.badge.img+14
hi !
FME name machine parameter does it exist? I see the name of my computer at the beginning of the log but I don’t find where is this parameter.
Thanks !
Best answer by dustin
You can use the EnvironmentVariableFetcher, using the environment variable COMPUTERNAME. You can also do this from PythonCreator or PythonCaller using the code below.
import fmeobjects,socket
class FeatureCreator(object):
"""Template Class Interface:
When using this class, make sure its name is set as the value of the 'Class
to Process Features' transformer parameter.
def __init__(self):
"""Base constructor for class members."""
pass
def input(self, feature):
"""This method is called once by FME to create FME Feature(s).
A created Feature is emitted through the self.pyoutput() method.
Any number of Features can be created and emitted by this method.
:param fmeobjects.FMEFeature feature: Dummy FME Feature passed in by
FME. It can be ignored.
newFeature = fmeobjects.FMEFeature()
newFeature.setAttribute('hostname',socket.gethostname())
self.pyoutput(newFeature)
def close(self):
"""This method is called at the end of the class."""
pass
dustin
Forum|alt.badge.img+36
  • Sep 9, 2024 12:15 PM UTC
def __init__(self):
pass
def close(self):
pass
alc33
  • Dec 23, 2024 2:21 PM UTC
​@dustin Thank you for your answer and sorry to respond so late !
It works very well !
