FME Emailer and Multiple Attribute Lists
  • May 27, 2019 11:25 PM UTC
  • 236 views
dmerrick
I am trying to figure out how to have multiple lists in a single email.
I have a ID field for features missing invert elevations, being passed to a list builder, list concatenator, to an attribute manager (to insert some text before the ID's), and then the Emailer transformer.
I want to include the construction drawings each ID has, so I am using a DuplicateFilter and going through the same series of transformers but the emailer sends out 2 different emails, each with the different list.
I am testing on FME 2018.1 and will be publishing this to FME Server 2018.1 as well.
Thanks!
Best answer by nielsgerrits
The number of features reaching the Emailer will result in the same number of emails. So you have to merge the two features into one.
Several ways to do this, you could use a FeatureMerger (for incoming features from two different directions) or an Aggregator (two features from the same direction). In both cases the attributes or lists you want to merge must have different names to prevent one overwriting the other one.
mergefeaturessample2019.fmwt
nielsgerrits
Forum|alt.badge.img+67
  • May 28, 2019 4:44 AM UTC
danilo_fme
Forum|alt.badge.img+58
  • May 28, 2019 11:41 AM UTC
Nice Job!
dmerrick
  • May 28, 2019 6:31 PM UTC
Thanks so much for the solution, I used the aggregator method on each section, before aggregating those into a single feature which I was able to stylize in the HTML Report Generator to send a single email with multiple sections and lines detailing any errors found.
Thanks!
