fme_data field converted to dateonly field, problem when writing to SDE
  • Jun 2, 2025 12:31 PM UTC
  • 7 replies
  • 254 views
sijmensp
Forum|alt.badge.img+3
I upgraded a workspace with a dynamic writer from FME 2022 to FME 2024. When inspecting the schema before writing there is fme_date and fme_datetime time fields. When writing to geodatabase it created dateonly fields from the fme_date fields when using FME 2024. When writing to SDE we get a ORA-210 / ORA-308 (invalid field type). What is the solution to this problem? I posted this before as addition to another forum topic. However someone from FME suggested to make a new topic.
Forum|alt.badge.img+54
  • Jun 2, 2025 1:21 PM UTC
What version of SDE are you running?
Are you trying to update an existing feature class or create a new feature class?
sijmensp
  • Jun 2, 2025 2:06 PM UTC
The version of our ArcGIS geodatabase within Oracle is 10.8.1 according to our system administrator. We are writing data (DROP AND CREATE).
nielsgerrits
Forum|alt.badge.img+67
I’m not sure which version SDE accepts date only fields, but I think it is newer than 10.8.1?
As a workaround, if you use a dynamic workflow, I would try to edit the schema feature to search and replace fme_date with fme_datetime.
  • Jun 2, 2025 3:15 PM UTC
So you don’t see any warning such as?
sijmensp
  • Jun 3, 2025 7:34 AM UTC
Thanks for your responses. I'll try the workaround. I am directly writing into a lokal GDB using FME (which I do not get the warning, correct version) and then try to copy manually using ArcGIS Pro to the Oracle database on the older version.
sijmensp
  • Jun 19, 2025 2:04 PM UTC
11.2.0 is indeed required for the enterprise geodatabase version. Found out after contact with ESRI. Still working on the workaround. I'll update the topic when I got it to work. See Client and geodatabase compatibility—ArcGIS Pro | Documentation
sijmensp
  • Jun 27, 2025 11:57 AM UTC
I made the following alterations to my script.
-in the schema for writing fme_date fields are converted to fme_datetime  to prevent writing dateonly fields to the portal enterprise geodatabase
-In the schema for writing fme_int64 fields are converted to fme_int32 to prevent writing bigints fields fields to the portal enterprise geodatabase.
-Although I Implemented at first, it is not necessary to convert the values with only a data to a value with a date and time using the datetimeconverter
As this information could be useful to readers I added here in my topic.
