FME - Blue Marble HTDP Integration?
Does the new Blue Marble intergation allow for Horizontal Time Dependent Positioning (HTDP) reprojections? The blue marble software does allow for this type of transformation and I want to know if FME can take advantage of this if I have Blue Marble installed.
fmelizard
Forum|alt.badge.img+18
  • January 21, 2013
Hi Jeremy,
I've not tested it, but I believe that the BlueMarbleReprojector will give you complete access to all the BlueMarble functionality, which should include this. I'll be in touch with our colleagues there and get a definitive answer. Note that you need to purchase the integration from BlueMarble to get it to work, but I'm sure they can provide a trial license as well.
Dale
  • January 22, 2013
Jeremy, unfortunately we did not get HTDP support out in this version.  However, if it is something that users are looking for we could add it in a future version.  Thank you for you interest.
Patrick
