FME AR: features below 0
  • January 22, 2020
  • 42 views
nielsgerrits
Forum|alt.badge.img+64
The What’s New in FME 2019.2 blog contains some writing about FME AR and underground features.
FME AR
  • Load an AR model in 1:1 scale in addition to the existing “table model mode”. Pick the scale you want from a list, then inspect your data against a real backdrop.
  • See an improved display for underground features (those that are below 0).
  • See improved texture appearance when there is an ambient material property.
But I'm not sure how to make this happen? What I tried was to read a cable feature, create a "floor" level with a boundingboxreplacer and an extruder, offsetting the cable to 10 meters below the floor. Looks OK in the inspector but in the app it seems the model is positioned with the lowest part on the detected surface.
mark2atsafe
Forum|alt.badge.img+59
  • January 24, 2020
Hi Niels,
There are a couple of bugs right now and I wonder if they are affecting you. I meant to mention them in my post last week, but forgot.
Apparently the vertical anchor (fmear_anchor_z) value is currently ignored by the app. Right now the app uses z=0 when loading the model. For example, if your elevation was 50m, the app would still use 0, meaning the model is likely to appear above you, rather than below. Obviously we'll need to fix that one.
The second issue is that the AR Writer "adjusts" the model vertically, i.e. it moves the model along Z so that the model centre is at z=0. That's a writer bug that will be fixed as well.
So I'm thinking one of these might be the cause of this. Does that make sense to you? I'm not sure if you are using a z value for your anchor (if you're not, then the first issue won't apply) or whether your data has z values (again, if not, the second issue won't apply).
Either way I hope we'll get fixes for them as soon as possible.
angusatsafe
Hi Niels,
We should have fixed the vertical issue in 1.4.0+. Version 1.5.0 is available now. Thanks for your feedback.
Angus Lau
Safe Software Inc.
nielsgerrits
Hi Niels,
Angus Lau
Safe Software Inc.
Thanks! Will test this anytime soon.
jonas_nelson
Forum|alt.badge.img+28
Hi Niels,
@mark2atsafe I really hope you will provide some nice tutorials, blog posts, articles or webinars when you get this working. What I can see from this and Dmitris demos look very interesting indeed, and I look forward to be able to pick up my smartphone and watch a virtual building in the correct georeferenced position!
