fme and arcpy - calling arcpy functions, where?
  • December 18, 2013
  • 20 views
I tr to execute the following arcpy function from a fme workbench:
arcpy.CalculatePolygonMainAngle_cartography("FeatureLayer", "poly_angle")
from the PythonCaller transformer to calculate a polygons main angle. What I can't really understand (as my python skills are absolute nonexisting) is how to wrap than inside the template function interface. I have tried to integrate the arcpy- function like this:
import fmeobjects
import arcpy
def angleFeature(feature):
    ang = arcpy.CalculatePolygonMainAngle_cartography("FeatureLayer", "angle")
    feature.setAttribute("angle", ang)
but when trying to run the workbench I get the following error
ERROR 000732: Input Features: Dataset FeatureLayer does not exist or is not supported
so Im stuck with the problem that the function cant find my source (wich is a Geodatabase_SDE reader. It also feels that once I get the features into the function, CalculatePolygonMainAngle will write the angle to the attribute "angle" and then fme will write it once again in feature.setAttribute.
I obviously dont know much python, perhaps someone else knows and might help out?
fmelizard
Forum|alt.badge.img+19
  • December 18, 2013
Cant help you much about the python, there are better experts for that in the community, but I can provide you with the FME solution: the PolylineAnalyzer transformer from the FME Store.
Hope this helps,
Itay
  • December 18, 2013
Itay, I have thought about that transformer but couldn't find a way to use it as I couldnt find much . The ArcPy function calculates the "longest collection of segementsthat have similar orientation" The PolylineAnalyzer documentation is a little sparse, do you have any idea on how to use it instead?
fmelizard
  • December 18, 2013
If I understand the definition correctly it would be a matter of testing the objects resulting from the PolylineAnalyzer for the object with the maximal lenght in the same azimuth/angle category.
All of these attributes are gathered by the transformer.
You can also test your FME results with the results of the script in the ESRI environment.
Itay
