Find points of a polygon that touch a line.
  • Jul 3, 2023 9:36 AM UTC
  • 123 views
Find the points on a polygon that are perpendicular to a line as in the screenshot.
Existing features are the polygon(s) and line A.
Pts a and b are required.PointsRequiredThanks very much for any help and ideas.
nielsgerrits
Forum|alt.badge.img+67
Have done something like this in the past, where I wanted to determine the start and end positions of road barriers along roads, using measures. I think you can use that technique for this case, given that there are vertices on point a and point b.
Steps would be:
  • Generate a distance measure for line A using the MeasureGenerator.
  • Explode the polygon to vertices using a Chopper. If not enough points, you can use a Densifier.
  • Find the closest line A for each polygon point. The measure from the line will be added to the MatchedBase.
  • Expose the measure from the point using a MeasureExtractor.
  • Find the min and max measure.
nielsgerrits
Steps would be:
Workspace demonstrating this.
  • Jul 3, 2023 12:14 PM UTC
Steps would be:
Hi, Thanks for your reply. I'll have a look at the workspace and methodology you recommend and let you know how it goes.
Z.
