Filter an input of 169,000 records in one csv against a second input of 100 records from another csv
  • Sep 26, 2025 10:15 AM UTC
  • 94 views
scarter
Forum|alt.badge.img+10
Hello Forum,
I am reading in two .csv files into FME Form...
csv 1
Candidate_UPRNs.csv
This has just one column: candidate_UPRN. It contains 100 records. Each record contains a UPRN value in the candidate_UPRN attribute.
Note for those outside UK: the UPRN is the unique property reference number (UPRN) from the Local Land and Property Gazetteer (LLPG). As the name suggests, the UPRN is unique and can not be repeated. UPRNs are managed in the LLPG.
csv 2
LLPG_PAs.csv
This is an extract our entire LLPG with around 169,000 records. It contains multiple columns including UPRN.
I want to filter LLPG_PAs.csv down so that I am only using the records that match (using the UPRN value) with the records in candidate_UPRN.csv (i.e.: the 100 records).
Before I take the workspace on further from that point I need to establish the filter first.
I’ve looked at SpatialFilter, but not sure that’s ideal. Any advice would be welcome.
Thanks,
Forum|alt.badge.img+54
  • Sep 26, 2025 10:28 AM UTC
FeatureMerger with LLPG_PAs.csv as the requestor and Candidate_UPRNs.csv as the Supplier and join on UPRN. Matched records will exit via the Merged port.
The FeatureJoiner would also be an option
Forum|alt.badge.img+63
Agree with ​@ebygomm but would also like to suggest the DatabaseJoiner as an alternative.
