file path as published parameter for Dynamic Input Reader
  • Jul 11, 2014 12:51 PM UTC
  • 81 views
Hello all ,
I am trying to read all the file paths from a text file which is going to be the source file paths for the dynamic reader . I am using below private variable to generate the source reader's path
# Get the file from a published parameter
ListFile = (FME_MacroValues['Config_File'])
f = open(ListFile,'r')
featureTypes = ''
# Read the file and add each line to the featureTypes Variable
featureTypes = f.read()
f.close()
#Return this list to the parameter
return featureTypes
And I am publishing it to FME Server . When I run the job I am getting error saying it cannot read "C:\\temp1 C:\\temp2 C:\\temp3" .
Any suggestions ???
gio
Forum|alt.badge.img+15
  • Jul 11, 2014 1:59 PM UTC
Do you feed it individually qouted file/paths?
might this be the cause?
  • Jul 11, 2014 2:04 PM UTC
Hello Gio,
Yes I tried and that worked
but how can I do the same using python ?
  • Jul 12, 2014 9:14 AM UTC
correction for indentations.
f = open(ListFile, 'r')
featureTypes = []
for s in f.readlines():
    featureTypes.append('"%s"' % s.strip())
featureTypes = ' '.join(featureTypes)
