FeatureWriter, ESRI Shape, and a single feature = problems
  • June 11, 2021
  • 28 views
lifalin2016
Forum|alt.badge.img+40
Hi list.
I'm using FeatureWriter to write some data into a temporary ZIP file, that is being attached to an email.
When I have the situation, where a single feature needs to be output in ESRI Shape format (inside the ZIP), it seems that the file isn't being written at all !?!?
I've tried different file locations, different file names etc., nothing works.
But if I add a Cloner with a value of 2, the file gets written as expected.
What gives ?
Best answer by hkingsbury
I'm taking a guess here that you're using a dynamic writer with the schema source set to "Schema From Schema Feature?"
You need to make sure that you don't have an attribute called "fme_schema_handling"
See here https://community.safe.com/s/article/dynamic-workflows-advanced-example-modifying-the-s
hkingsbury
Forum|alt.badge.img+67
  • June 13, 2021
lifalin2016
  • June 15, 2021
Thanks @hkingsbury​
I do indeed use dynamic output in a FeatureWriter with schema source set to "Schema from Schema Feature".
However, the final tidbit, about why it's necessary to remove 'fme_schema_handling' from the features, which explains what happens, is missing in the picture. @virtualcitymatt​ explained that in another of my questions, and the article filled in the blanks.
If 'fme_schema_handling' is set to 'schema_only' on the features, which will happen when you merge a schema feature from a FeatureReader onto the data features, the FeatureWriter will remove the first received feature from the stream, and use this for schema definition only.
If 'fme_schema_handling' is missing (or set to a different value??), it will still use the first feature for schema definition, because dynamic output is requested, but leave it in the data stream.
This does explain the behaviour I've encountered.
