FeatureWriter - Attributes
  • Jun 29, 2017 7:33 PM UTC
  • 5 replies
  • 98 views
danilo_fme
Forum|alt.badge.img+58
Hi all,
My workspace is using the transformer FeatureWriter in SQL Server.
I would like to recover the attribute Operador from my source data.
The attribute Operador was simulated to be the transformer fme_basename.
How can i extract it after the transformer?
Attached my template file.
Thanks
Danilo de Lima
Best answer by erik_jan
HI @danilo_inovacao,
At this moment the FeatureWriter does not output the features and therefor does not output any attributes.
It has been added as an idea on the Knowledge Board:
https://knowledge.safe.com/idea/23367/add-output-port-to-featurewriter.html
erik_jan
Forum|alt.badge.img+26
  • Jun 29, 2017 9:23 PM UTC
Hi @danilo_inovacao,
You could try using the VariableSetter (before the FeatureWriter) and the VariableRetriever (after the FeatureWriter) to pass the attribute across.
fmelizard
Forum|alt.badge.img+22
  • Jun 29, 2017 10:49 PM UTC
You could take a single feature using the Sampler transformer and then aggregate the Summary and single feature after the FeatureWriter transformer using an Aggregator transformer.
  • Jun 29, 2017 11:05 PM UTC
This workflow could be a workaround in the interim.
  1. FeatureHolder: Wait for writing completion.
  2. Sampler: Sample a single feature.
  3. AttributeKeeper: Remove all attributes optionally.
  4. FeatureMerger: Merge the summary feature to the source features unconditionally (Join On: 1 to 1).
The FeatureHoder and the Sampler are not essential when there was just a single destination dataset in the FeatureWriter.
  • Apr 17, 2019 10:39 PM UTC
This didn't work for me - nor did using "Additional Summary Attributes" of the writer. I think I have to use the 1:1 Merge.
