FeatureReader with PointOnAreaPolygon
  • Jul 13, 2018 9:16 AM UTC
  • 42 views
sunsilk11
Hi I have a point (10 million rec) and polygon feature (9000 rec) class in SDE SQL Server 2012. I am using a FeatureReader to read the point fc, following which I need to get count of points within each polygon. This is what I get when I run workspace output doesn't seem correct:
Reader format `GEODATABASE_SDE' does not support querying by spatial predicate, but supports envelope queries. FME will create equivalent results by performing spatial predicate calculations locally. Performance should not be affected.
Any idea?
andreaatsafe
Forum|alt.badge.img+17
Hi @sunsilk11,
The answers on this Q&A; post should give you some ideas as to how you can work around it: https://knowledge.safe.com/questions/60361/does-the-featurereader-spatial-filter-work-on-orac.html
- Andrea
