FeatureReader use user parameter for the coordinate system
alc33
Forum|alt.badge.img+10
Hi!
I would like to create a workbench with a lot of flexibility for the users. I use a FeatureReader with a spatial filter. I create a user parameter to chose the system of coordinates. So I would like to use it on the Featurereader but there are no option. Do you know a way to indicate to this transformer the system of coordinates? I suppose the spatial filter will work if the datas are in the same system but I would prefered to force it.
Thanks !
Best answer by redgeographics
You can link the FeatureReader’s Coordinate System parameter to a User Parameter through the Navigator, that should work.
Forum|alt.badge.img+50
  • August 2, 2024
alc33
  • August 2, 2024
Thank you @redgeographics it works very well !
