FeatureReader stops prematurely when reading from large Oracle table
  • Mar 19, 2018 3:36 PM UTC
  • 9 replies
  • 116 views
Hi guys,
We have a routine job that reads 5 million records from a Oracle non-spatial table (runs on fmeserver, 2017). During a recent run it completed successfully but only processed 2 million records. The log looks normal, it is as if the source db only had 2 million records - which is not the case when checked. Normally we would get a oracle/connection error if there was a network failure - the job does take a while to run. Has anyone seen behaviour like this before? Thanks!
Grace
  • Mar 19, 2018 3:44 PM UTC
Have you also checked the server logs for warnings or errors?
Most importantly check fmeserver.log and fmeprocessmonitorengine.log
  • Mar 19, 2018 4:23 PM UTC
Hi @david_r. We have 5 engines, I'm not sure how to differentiate between them reading the server logs. The following messages repeated leading up to the job completing. The error "Invalid response length returned..." started to appear about 5 min before the job completed. Not sure what to make of that...
Invalid response length returned by FME Engine, expected 369,295,873 but read 511 bytes
Could not read FME Engine name. Registration cancelled.
Disconnected FME Engine: on host
Failed to register FME Engine.
Accepted new FME Engine connection.
Registering FME Engine...
Invalid response length returned by FME Engine, expected 369,296,131 but read 807 bytes
Accepted new client connection
Successful login by user admin
FME Server license does not allow more than maximum of 5 FME Engine(s).
Job 6,136: Pulled from result queue for delivery.
Job 6136: FME response successully processed
Hi @lc
Have you seen this article?
A few things stood out here that may apply to your situation:
  • oracle client configuration errors
  • large datasets with memory intensive operations
Do you get the same behaviour if you use the Oracle reader instead of a FeatureReader?
Is there any way you can read and process smaller chunks over multiple jobs and see if the problem persists?
  • Mar 19, 2018 5:15 PM UTC
Hi @lc
Hmm i don't see those errors replicated in my log. i don't see anything pointing to a network or memory issue. we've run this job successfully before, a number of times. Updating the reader or splitting the job would require significant changes to a complex process. would like to avoid if possible.
  • Mar 20, 2018 9:03 AM UTC
I don't think that's the issue. I'd primarily look for ORA-xxxx errors etc.
  • Mar 20, 2018 9:05 AM UTC
You may also want to try creating a super simple workspace that does nothing else than read the Oracle table and send everything to the NULL writer. I'm curious to know if that works or if you get the same error.
nielsgerrits
Forum|alt.badge.img+67
NULL writer? Learned something new today, thanks.
  • Mar 20, 2018 9:17 AM UTC
Surprisingly handy sometimes! :-D
jneujens
  • Mar 20, 2018 1:43 PM UTC
How long is the process running? It could be that it takes so much time that FME loses connection with your database?
