FeatureReader: single merged feature type
  • October 17, 2019
  • 5 replies
  • 236 views
fikusas
Forum|alt.badge.img+5
Is it possible to merge all feature types with all attributes using FeatureReader? <General> port is not an option, 'cause it gives geometry only without attribute information.
itay
Forum|alt.badge.img+19
  • October 17, 2019
The generic port does provide the attributes but you need to expose them, luckily you can use the import function in the attributeexposer and get all the attributes.
  • October 17, 2019
The <Generic> output port will give you both the geometry and the attributes, but you'll have to expose the attributes manually. You can verify this by sending the <Generic> port to the Inspector and click on an object and see the attributes on the right.
fikusas
  • October 18, 2019
Yeah, I know that. But in order to expose attributes I need to know what they are. Any other reader automatically exposes all atributes without manually instructing what attributes to expose. This is kind of behaviour I want from FeatureReader.
itay
  • October 18, 2019
You can vote up this idea: https://knowledge.safe.com/content/idea/24774/add-import-function-to-featurereaders-attribute-to.html
Or add a new one.
fikusas
  • October 18, 2019
