FeatureReader data path
  • Dec 7, 2018 6:47 PM UTC
  • 8 replies
  • 318 views
jdh
Forum|alt.badge.img+41
I have a workflow where I need to use the featureReader to read in some data. The dataset parameter is an attribute containing a wildcard character in the path.
Is there any way of determining the actual file a feature belongs to, as the fme_dataset attribute does not seem to be present on the feature (it's not a matter of exposing it, it's not there to be exposed).
nielsgerrits
Forum|alt.badge.img+67
I can't reproduce this with a Text File reader but I think I have seen this before... What is the format? What FME version? Did you merge initiator attributes?
jdh
  • Dec 7, 2018 7:08 PM UTC
2018.1 (18528). The actual data is xml, but I also tried a few other vector formats. Raster formats do have the fme_dataset present.
Merging initiator attributes gives the initiating feature's fme_dataset, not merging attributes it's not present.
nielsgerrits
Couldn't reproduce in 2016 (sorry) but can reproduce in 2018.1.1 (18567) with XML reader and path without wildcard. Weird, think it might need a ticket.
Workaround could be to use a FeatureReader Directory and File reader first, then merge initiator attribute, but this is not how it should work I think.
Forum|alt.badge.img+54
  • Dec 7, 2018 7:30 PM UTC
I can get the fme_dataset value with no issue in 18552. You do need to expose as both a schema parameter and in the additional attributes to expose box if using a generic output port
jdh
  • Dec 7, 2018 7:37 PM UTC
With an xml file? I just tried in build 18552, and it still comes up as missing, even when using a hardcoded path and feature type.
  • Dec 7, 2018 7:38 PM UTC
Yes, just updated with a screenshot of the output above
jdh
  • Dec 7, 2018 7:46 PM UTC
That's special. I wouldn't have thought to expose the schema attribute in the parameters, especially since the feature reader is set to Data Features.
  • Dec 7, 2018 7:51 PM UTC
I ran into the same problem before. I think it might be inconsistent between file types but I didn't think too much about whether it was the 'correct' behaviour as long as i had something working.
