FeatureReader and the Schema output port.
  • May 30, 2019
  • 7 replies
  • 88 views
bjudes
Forum|alt.badge.img+10
I created a workspace to pull aerial imagery stored in a number of different folders. As a result I have 3 FeatureReaders, and in order to get the imagery to write with .tfw I need the schema output port to be connected to the writer. The problem is I need to run the workspace and wait to see which FeatureReader is going to first output a file and then ensure this is the schema output port running to the writer. I want to start using this workspace with WorkSpaceRunner but unless it is completely automated I won't be able to? Am I going wrong somewhere, is it possible to fix this? I don't want to have to wait and manually connect the schema output port.
Also with the same workspace, I have noticed a change (bug?) since I upgraded to 2019.0. In 2018.1 when I uploaded a particular AOI shapefile the output came from the TIFF_READER (see image below), but now (2019.0) it comes from the Feature_Reader_2. There is no reason for the change, it should be sending the vast majority through the TIFF_READER and when there are two images for one area the Feature_Reader_2 then outputs the most up to date. This no longer works as everything is coming through the Feature_Reader_2 now. I've uploaded the workbench. I hope this makes sense, thanks for any help. B
Forum|alt.badge.img+46
  • May 30, 2019
Do you really need the 3 featurereaders? Is it not possible to manage what you need with one?
  • May 30, 2019
I'm not clear why you need to use Schema feature and Dynamic writer feature type. The TIFF writer creates world files (*.tfw) by default, regardless of whether it's configured as dynamic or not.
bjudes
  • May 30, 2019
When I was writing using the Dynamic writer I was not getting .tfw unless I had the Schema port connected, I am now no longer using a Dynamic writer and it has solved the problem. Thanks for the help.
bjudes
  • May 30, 2019
I am reading the UNC path for each file, these are broken into 3 separate lists, therefore I want to read 3 different 'Datasets' (see below). I thought this was the only way to achieve this, I am not an expert, I could well be doing it the wrong way, is there a way to achieve this using one FeatureReader? Thanks B
  • May 30, 2019
I was wrong. As you said, dynamic writer didn't generate tfw files unless receiving schema feature. Strange...
Anyway, why do you need to configure the writer with dynamic mode?
bjudes
  • May 30, 2019
'Why do you need to configure the writer with dynamic mode?'
I don't, that was my mistake. I only realised when you pointed the above out and went back and changed it.
B
  • May 30, 2019
You can use an attributecreator to create the filepath attribute depending on your tests
e.g. if 15cm_Year = 2017 filepath = 15cm_path
then you use this newly created filepath in a single feature reader
