Fanout by row attribute value
  • Jul 23, 2019 10:42 AM UTC
  • 12 replies
  • 121 views
I need to make an export of my data with a format like this:
I want the output to be in seperate files (fanout) based on a single row value per group
I grouped the data by groups, so each group has unique attributes. How I can fanout and get the filename to be a single row attribute? ('bestandsnaam'), so in this case '504.pfrl'
Best answer by ebygomm
What does your data look like before you explode the attributes?
Forum|alt.badge.img+54
  • Jul 23, 2019 10:49 AM UTC
  • Jul 23, 2019 10:57 AM UTC
Before it looks like this:This would be easy to fanout by 'bestandsnaam', but then I wouldn't knwo how to produce a layout like this:
  • Jul 23, 2019 11:34 AM UTC
You should be able to just produce a text_line_data attribute with multiple lines and the correct layout write to a text file, then fanout on 'bestandsnaam'
e.g.
  • Jul 23, 2019 12:34 PM UTC
e.g.
Thank you, that seems to get me closer. I mad a text line attribute like you described:
But how do I write it? I tried using a generic writer set to .txt and manually selecting my textline-attribute:
But this results in an empty .txt file
  • Jul 23, 2019 12:35 PM UTC
I would use the text writer and the attribute needs to be called text_line_data. I typed it wrong in my answer originally.
  • Jul 23, 2019 12:55 PM UTC
That brought me even further, almost there! The only thing is that 'enter' does not seem to work. tried both Newline (/n) and Carriage return (/r):
but everything is written away as 1 line without enters:
  • Jul 23, 2019 1:02 PM UTC
You will need to enter carriagereturns using the special characters option on the left in the text editor
  • Jul 23, 2019 1:03 PM UTC
I did! Same result unfortunately.
  • Jul 23, 2019 1:05 PM UTC
Your screen shot shows Line Feeds not carriage returns...
  • Jul 23, 2019 1:08 PM UTC
I know, I tried both since carriage returns didn't work:
result:
  • Jul 23, 2019 1:19 PM UTC
result:
Ah, i think it is because if you are viewing in Notepad you need both the line feed and the carriage return. Viewing text files in other editors will show slightly different output.
  • Jul 23, 2019 1:22 PM UTC
Yes!! You are my hero! Thank you so much!
