Fanout by Attribute Database Username SQL
  • Aug 5, 2014 3:14 AM UTC
  • 43 views
When using 'Fanout by Attribute' on MS SQL Spatial Writer I can't seem to get it to write using the Database Username, it always writes out to dbo.
Is there a tip or trick I may be missing?
Thanks
  • Aug 5, 2014 12:06 PM UTC
try using a Dataset fanout (see the Writer's advanced settings in the Navigator pane) rather than the feature fanout settings.
David
  • Aug 5, 2014 10:25 PM UTC
I think that only seems to work for file directories and not SQL Server?
Cheers
