Fanout and open folder
  • Jul 10, 2018 6:06 PM UTC
  • 6 replies
  • 92 views
mr_fme
Forum|alt.badge.img+9
I have a Workspace that I need in output create a folder and a subfolder, and in this subfolder the file needs to be saved. And after the file has been saved, I need the folder to open automatically, it can be done by the FME?
Thank´s
debbiatsafe
Forum|alt.badge.img+24
Hi @mr_fme
A FeatureWriter with either a SystemCaller or PythonCaller would be able to open the parent directory automatically after the file(s) has been written.
danilo_fme
Forum|alt.badge.img+58
  • Jul 10, 2018 8:49 PM UTC
Hi @DebbiAtSafe
This transformer SystemCaller is very interesting.
mr_fme
  • Jul 11, 2018 11:32 AM UTC
Hi @mr_fme
Very good. Thank´s
mr_fme
  • Jul 11, 2018 12:19 PM UTC
Hi @mr_fme
unfortunately neither the pythoncaller nor the systemcaller are working .. see the answer from pythoncaller:
PythonFactory failed to load python symbol `FeatureProcessor 'Factory proxy not initializedf_21 (PythonFactory): PythonFactory failed to process featureA fatal error has occurred. Check the logfile above for details
SystemCaller:
SystemCaller: Failed to Execute `start"" "C:\\Users\\FME\\Desktop\\Week\\18_07_10\\"'
Can you help me?
  • Jul 11, 2018 1:02 PM UTC
SystemCaller:
Can you help me?
  • Insert a space between the start command and the next double quotation mark.
  • Make sure that the specified folder definitely exists.
mr_fme
  • Jul 11, 2018 1:20 PM UTC
Help me a lot.
Thank you very much
