Failed to create unique list Python
  • Apr 1, 2019 3:54 PM UTC
  • 65 views
fer_ruiz2
I have written a Python code to retrieve a list of  unique values from several rows with several attributes (in the example below, there are 5 attributes).
The problem with this code is that the output field has only the result for the first row. It copies it to the rest of the fields. Here is the code:
import fme
import fmeobjects
index =  0
list_yes = []
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def compare_attributes(feature):
    global list_yes
    global index
    s1=feature.getAttribute('Att_1')
    s2=feature.getAttribute('Att_2')
    s3=feature.getAttribute('Att_3')
    s4=feature.getAttribute('Att_4')
    s5=feature.getAttribute('Att_5')
    myList_1 = [s1,s2,s3,s4,s5]
    for i in myList_1:
        myList_2 = myList_1[index:]
        if i!='':
            for j in myList_2:
                if i == j:
                    list_yes.append(i)
                else:
                    pass
        index = index +1
    list_set = set(list_yes)
    unique_list = list(list_set)
    var_def = str(unique_list)
    feature.setAttribute('NEWATT',var_def)
I have been looking for another built-in Python function and I found the following :
list(set(feature)
so i implemented it in the code like this:
import fme
import fmeobjects
    unique_list = list(set(myList_1))
    feature.setAttribute('NEWATT',unique_list)
This code doesn't work, it shows the following error:
2019-04-01 17:50:54|   0.5|  0.0|ERROR |Python Exception <TypeError>: Failure to convert list unicode values to native UTF-8 values.
2019-04-01 17:50:54|   0.5|  0.0|ERROR |Error encountered while calling function `compare_attributes'
2019-04-01 17:50:54|   0.5|  0.0|FATAL |PythonCaller_31(PythonFactory): PythonFactory failed to process feature
2019-04-01 17:50:54|   0.5|  0.0|ERROR |A fatal error has occurred. Check the logfile above for details
Is it possible to correct this?
erik_jan
Forum|alt.badge.img+26
  • Apr 1, 2019 3:57 PM UTC
Do you really need to do this in Python?
The DuplicateFilter transformer is built for this task.
jdh
Forum|alt.badge.img+41
  • Apr 1, 2019 4:00 PM UTC
You are using the function interface which processes each feature independently. If you want a unique set of values across all features, you need to use the class interface.
