Extract Schema and Table Names
  • Feb 4, 2026 12:16 AM UTC
  • 93 views
vxn43
Forum|alt.badge.img+20
I have a SQL Server Database that has 156 tables.
I need to extract the schema for each table and table names into a CSV.
I know one way is to add all 156 tables to the workbench as separate Readers and then use FeatureReader (with Features to Read set to Schema Features). This could be a start, but it seems rather tedious.
Is there a better way? I want to write to a CSV that has the attributes in one column and the table names in another column.
Any thoughts on the best way to tackle this?
Best answer by _jacques_
Good morning!
You could use a DatabaseQuerier (or SQLExecutor) and select the table names from the  INFORMATION_SCHEMA.TABLES view. Then use the result from that in a FeatureReader to read the schema of every table.
SELECT TABLE_NAME, TABLE_SCHEMA FROM INFORMATION_SCHEMA.TABLES
You can add any specific filters in the SQL query as a WHERE clause or in the FME workbench using Tester/AttributeFilter transformers.
Then in the FeatureReader you want to set Feature Types to Read as
@Value(TABLE_SCHEMA).@Value(TABLE_NAME)
_jacques_
Forum|alt.badge.img+19
  • Feb 4, 2026 7:07 AM UTC
Good morning!
