error while running it suddenly getting
  • Oct 4, 2019 7:24 AM UTC
  • 164 views
rakeshreddy0996
Geodatabase Error (-2147219884): The Field already exists.
FileGDB Writer: Could not create feature class 'IMPORT_FIELDS'
... Last line repeated 2 times ...
Geodatabase Error (-2147418113): Unexpected operation.
FileGDB Writer: Could not disable Load Only Mode for feature type 'IMPORT_FIELDS'
FileGDB Writer: Could not free Write Lock for feature type 'IMPORT_FIELDS'
error occur while running
thanks in advance
Best answer by mileslee
It seems that you have multiple feature writers write to the same feature class, and one of them locks it which does not allow others to write into it. You would need to make sure that only one feature writer is writing to the feature class.
  • Oct 4, 2019 7:32 AM UTC
Does the target feature class and/or file geodatabase already exist?
If yes, does the error still occur if letting FME create the file geodatabase from scratch?
  • Oct 4, 2019 7:34 AM UTC
rakeshreddy0996
i will check revert on 9 oct
thanks for replaying me
rakeshreddy0996
