Entering the same Attribute Value for multiple Input Attribute within AttributeManager
  • Mar 20, 2024 2:57 PM UTC
  • 288 views
marianny
Participant
I’m a newbie using FME although I have also experience with SQL and GIS. I recently started working on a transformer using the AttributeManager. This contains ~ 40 attributes and the goal is to convert part of those attributes based on different conditions, and others attributes based on a same expression: @double(@CurrentAttribute())
I was wondering if there was a method to apply the same attribute expression on several input attributes at once while keeping everything in one transformer.
Thank you in advance!
Best answer by becchr
Hi marianny, I think the transformer ‘ExpressionEvaluator’ is what you want?
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/expressionevaluator.htm
You can select the attributes you want to overwrite and use @CurrentAttribute() (last one in FME Feature Attributes dropdown) to do the same calculation on the different attributes
becchr
Forum|alt.badge.img+35
  • Mar 20, 2024 3:07 PM UTC
