engine
  • November 15, 2024
  • 8 replies
  • 68 views
sterla
With a permanent licence fme desktop hit much engines do we have available ?
Best answer by hkingsbury
FME Form can run a maximum of 8 instances of fme.exe - https://support.safe.com/hc/en-us/articles/25407717203725-Maximum-concurrent-FME-processes-error
That can be parallel processing, workspace runners, Form (Workbench), inspector
danilo_fme
Forum|alt.badge.img+52
  • November 15, 2024
Hi ​@sterla
Do you have a floating licenses from FME Form (Desktop)?
Please, open the FME Licensing Assistant to check this information.
Thanks in Advance,
Danilo
sterla
  • November 15, 2024
I have a fix licence
danilo_fme
  • November 15, 2024
Hi ​@sterla
You have a fixed license installed in your machine, so you have just one engine locally.
hkingsbury
Forum|alt.badge.img+67
  • November 17, 2024
sterla
  • November 17, 2024
Thank you for tou answer , but In the case of having a fixe licence how much engine do we have initially is it come with one engine or nothing ?
hkingsbury
  • November 17, 2024
Engines aren’t really a concept in Form. As the link I previously posted says, you can run 8 instances of fme.exe (which is effectively equivalent to an engine)
sterla
  • November 17, 2024
Yes but in the case of having a fme flow with an engine and I want to replace my engine of fme form by the one used in fme flow is it possible
hkingsbury
  • November 17, 2024
I don’t quite follow/understand what you’re wanting to achieve.
FME Form and Flow use different licenses, they are not interchangeable. If you require additional capacity in regards to engines or Form it is best to talk to your reseller.
The underlying ‘engine’ that runs process on both Form and Flow is the same (assuming both are the same version).
