Email from FME Desktop 2015
  • Oct 22, 2015 5:57 AM UTC
  • 89 views
I'm looking for a way to send an email from FME Desktop.
I went through this post but I cannot solve the issue:
https://knowledge.safe.com/AnswersQuestionDetail?id=906a0000000cqUpAAI
I have used "TCLEmailer" and "PythonEmailer" but I got the same error of the above post.
Python Exception <SMTPException>: SMTP AUTH extension not supported by server.
Error encountered while calling function `email'
PythonFactory failed to process feature
I disabled the antivirus but without any improvement.
I'm using Gmail for the emailing and I'm aware about the Gmail setting:
Email server: smtp.gmail.com
Gmail SMTP port (TLS): 587
Gmail SMTP port (SSL): 465
Please for your support.
I would be glad if anyone have a workspace with data sample or demo for the Email from FME Desktop.
Best answer by david_r
Hi
First of all, you need to use TLS, not SSL.
Secondly, you must activate support for "less secure apps" to send email through Gmail:
https://support.google.com/accounts/answer/6010255
Google has tightened the security around this a lot lately, so you might have to dig around in your account security settings to enable smtp from e.g. FME.
I was able to send an email with Gmail using these settings:
There are three alternative ways of sending email through Google, you might also want to consider the other two options:
https://support.google.com/a/answer/176600?hl=en
David
  • Oct 22, 2015 8:27 AM UTC
Hi
David
  • Oct 25, 2015 9:32 AM UTC
Thank you David. The first  way is work with me but I used SSL.
