Dynamically matching two unknown attributes
  • Jun 26, 2013 3:34 PM UTC
  • 42 views
Hi there,
I’d like to know if there is a method to match attributes with similar names.
To explain, here’s what the data will look like.
I have a Dynamic workspace that checks all files within two separate folder. So, the intent is to run this workspace on any features contained within, and the names of the shape files contained in those folders can be literally anything.
Let’s say Folder A contains the following files:
10001_AFR_ROADS_V1
10001_AFR_WATER_V1
10001_AFR_RAILWAYS_V1
And Folder B contains:
10XYZ_afr_Roads_v1
10X01_Afr_Water_v1
10001_AFR_Railways_v1_0
As you can see, there are similarities, but they are not identical. I want to know if there’s a way to compare the two sources and match any of those files that are “somewhat” similar. Ideally, a percentage. So for example, of it compare two of those files, and it detected that there was an 80% or higher similarity. I don’t need to see the percentage, I just need some leniency on matching the two sources up.
The two sources will always have quite high similarities, but I need this kind of process to compensate for slight differences.
Hope my explanation makes sense.
Thanks and Regards,
fmelizard
Forum|alt.badge.img+22
  • Jun 26, 2013 5:51 PM UTC
Hi Robbie,
I think for this case the fuzzy string comparer from the FME store can be of use.
Itay
