Dynamically create attributes using two lists: one with labels and one with values
  • Feb 6, 2019 8:36 PM UTC
  • 5 replies
  • 175 views
friesewoudloper
Participant
For each feature in my dataset, I have two lists: one containing labels and one containing values.
label{0}: ID
label{1}: Name
label{2}: Type
label{3}: Country
val{0}: 1
val{1}: Groningen
val{2}: Place
val{3}: The Netherlands
There may be more or less items in both lists. The contents of `label` may be completely different. But `label` and `val` always have an equal number of items.
How can I dynamically create attributes from these lists, with the contents of `label` as attribute names and `val` as attribute values?
erik_jan
Forum|alt.badge.img+26
  • Feb 6, 2019 10:33 PM UTC
Hi Willy,
Have a look at this FME Hub transformer:
This one worked for me.
Erik Jan
friesewoudloper
Participant
Hi Willy,
Erik Jan
Thank you @erik_jan. That looks like a good solution!
friesewoudloper
Participant
Update:
I added a PythonCaller with code based upon this example by @takashi
http://fme-memorandum-takashi.blogspot.com/2013/09/extract-list-attribute-elements-in.html
This does the job.
I'm also going to take a look at the solution @erik_jan provided. I 'd prefer a solution without Python code.
erik_jan
  • Feb 6, 2019 11:29 PM UTC
Hi Willy,
Erik Jan
Made a small example workspace: listkeypair.fmw
  • Feb 7, 2019 3:35 AM UTC
The ListKeyValuePairExtractor is a good solution.
Interestingly, JSON operations can do that too. FYI.
JSON Template Expression:
    let $labels := fme:get-list-attribute('label{}')
    let $vals := fme:get-list-attribute('val{}')
    for $i in (1 to count($labels))
    return {$labels[$i] : $vals[$i]}
