"Dynamic" output to SQL Server - no Table Qualifier/database schema ?
lifalin2016
Forum|alt.badge.img+29
I'm fairly new to using the dynamic output, but needed it for converting a set of shape files to SQL Server.
The writer has a "Table Qualifier" field, which in static writing designates the target database schema.
However, when used in dynamic writing mode, the value entered here is completely ignored, and the tables are all created in the "dbo" schema.
Is this WAD og a bug ? And if WAD, is it possible to set the database schema anyway ?
Cheers
Lars I.
Best answer by takashi
Hi @lifalin2016, I was able to reproduce the same symptom as yours, and I think it is a kind of bug. Hope someone from Safe will check this > @NatalieAtSafe.
A workaround I found is:
  • Set the qualified table name "<schema name>.@Value(fme_feature_type)" to the Table Name.
  • Leave the Table Qualifier field blank.
  • Set "fme_feature_type" to the Schema Definition Name explicitly.
In FME 2017.1, this seems to work as expected.
  • October 13, 2017
fmelizard
Forum|alt.badge.img+18
  • October 16, 2017
Hi @lifalin2016, I've been able to reproduce the issue as well. There is an existing problem report (PR74153) and I have linked your question to it. I'm sorry that you've encountered this issue. We will provide an update here once the report is addressed. In the meantime, @takashi's workaround should get you going.
lifalin2016
  • October 17, 2017
Thanks Takashi,
I did initially try with my target schema in the "Table Name" field, which failed. But adding the "Schema Definition Name" did the trick. I didn't recognize this decoupled "schema lookup value", but just assumed that FME always used "fme_feature_type".
lifalin2016
  • February 21, 2018
Any news on fixing this issue ?
dollargis
  • April 25, 2018
Yes, indeed the bug is still present in FME2018. Now I am struggling with a dynamic concatenation of the fully qualified table name to reach my goals of dynamically creating tables in other namespaces than public
  • May 27, 2018
Hi @TiaAtSafe, this question could lead to the same trouble.
Is there any update on the PR74153?
boubcher
Forum|alt.badge.img+11
  • May 28, 2018
@takashi
I have a similar problem with the Postgis and did the suggested workaround,postgis-writer1.png
but still writing to the public schema
  • May 28, 2018
boubcher wrote:
@takashi
The attached image cannot be accessed. Please post again.
boubcher
  • May 28, 2018
@takashi
  • May 28, 2018
boubcher wrote:
@takashi
You have set the dataset "GC [test] POSTGIS - 1" which is same as the destination dataset to the Schema Sources parameter. Is it intentional?
What would happen if you uncheck it here?
  • May 30, 2018
boubcher wrote:
@takashi
Have you modified the Schema Sources as I mentioned above?
The problem would not be solved even if you modified the Schema Sources, please contact Safe support.
