Dynamic Attribute creation
I have a json which i am getting through http caller.
This json contains data as well as schema details.
The schema details are like this
Column Name, ColumnIdentifier
and Data is like this [{ColoumnIdentifier : Value}]
Now i want to create new attributes based on schema details.
I have looked into python caller but i think you cannot create new attributes.
is there any transformer by which i can create new attributes using my json as an input?
or a python function to create new attributes
Forum|alt.badge.img+49
The JSONFlattener and/or JSONFragmenter should do the trick, although if you want to work with those attributes in other FME transformers you'll need to expose them (and in order to do that you'll need to know what they're called)
  • July 9, 2020
Thats the thing. It is dynamic. I cannot hardcode name of columns. This is why i am looking for a way to create new attributes based on that JSON.
I am using JSON Fragmenter and i am showing them in inspector but how can i create new attributes
Forum|alt.badge.img+31
  • July 9, 2020
What is the end result? If you are writing out to another file, it is not necessary to expose the attributes. If you need to expose the attributes on the canvas, your workspace is no longer dynamic
  • July 9, 2020
Very good point indeed.
Yes as an end result i am writing a feature class.
  • July 9, 2020
But still there is not way to create new attributes ?
from some list or json
  • July 9, 2020
If you want to create new attributes from values this can be done in an attributecreator, so you use the value in a one column to create the attribute name and the value in another to set the value, e.g.
The attributes will be created and can be seen in the feature information window and can be written out dynamically but will not be available on the canvas
You can use a pythoncaller to do the same
  • July 12, 2020
Hi
Thank you i am trying this approach and i tried exporting it to csv file for a test.
Still do not works. Is there something which i am missing ?
virtualcitymatt
Forum|alt.badge.img+34
smas1 wrote:
Hi
You will need to create a schema feature. You can give the SchemaSetter a go. It will add a list list in the structure which FME can use to define the schema on output. The transformer will add a list to each feature but you only need one feature. The feature with the schema list must be the first to get to the writer.
There are two special attributes you can set on the SchemaFeature which will help:
"fme_schema_handling"
And
"fme_feature_type_name"
You should double check the attribute names (I just wrote from memory)
set fme_schema_handling to: schema_only
and the fme_feature_type_name should the output feature type which all the rest of the features need to have set.
Here is a bit of a tutorial with some actual examples:
https://knowledge.safe.com/articles/1051/dynamic-workflow-tutorial-destination-schema-is-de-2.html
@ebygomm​ It works perfectly fine the way you describe it. But what is the point to create a non exposed attribute. One would work with its content, won't I?
  • August 30, 2023
You can write out unexposed attributes dynamically, so there are use cases where you would want to create an attribute and write that to a file, without any requirement to work with the content of those unexposed attributes.
