DWG Units
  • Apr 1, 2020 11:30 PM UTC
  • 371 views
deanhowell
Forum|alt.badge.img+24
Hello all,
I am trying to validate DWG files and that they have been drawn using metric units.
I have exposed the 'Read Drawing System Variables' and that gives me access to autocad_lunits but I am trying to figure out what the output means.
In the image below the autocad_lunits comes back with a value of 2 on the 0 layer but not sure what 2 really means.
Does anyone know what the range of options that AutoCAD produce or if there is another way to find what units are being used in the drawing?
Note: I know this particular drawing is in metric units but not sure what other values could be expected.
Best answer by becchr
hi @deanhowell, also the INSUNITS system variable might be interesting to check:
ACAD
FME
itsmatt
Forum|alt.badge.img+48
  • Apr 2, 2020 8:36 AM UTC
becchr
Forum|alt.badge.img+35
  • Apr 2, 2020 8:47 PM UTC
ACAD
FME
deanhowell
  • Apr 2, 2020 9:23 PM UTC
ACAD
FME
Thanks @becchr I think it will be a combination of this and lunits as at the end of the day I am trying to make sure the drawing has been drawn in meters.
deanhowell
  • Apr 2, 2020 9:27 PM UTC
