Dropdown list in Shape Output
  • Oct 11, 2019 5:41 AM UTC
  • 7 replies
  • 124 views
Hello,
I have an excel as a reader and i would like to add a writer for shape as output. In this, I am adding some attributes to which I need some values, which can be selected via a dropdown in shapefile. Is there any way of adding dropdown values in FME which will be reflected in shapefile as dropdown attributes?
Thanks in advance.
sigtill
Forum|alt.badge.img+25
  • Oct 11, 2019 6:09 AM UTC
You can add a Published Parameter from the navigator window with the dropdown options:
And then add an Attributecreator pointing to this Published Parameter:
  • Oct 11, 2019 7:47 AM UTC
Thanks, @sigtill , but I need this dropdown to be used in Shapefile in ArcGIS. Which by the above-mentioned process is not able to give.
sigtill
  • Oct 11, 2019 7:50 AM UTC
Ah, ok - I`m sure there is some better ArcGIS-people hanging out in the forum here, answering pretty soon :).
sipsysigh
Forum|alt.badge.img+12
  • Oct 11, 2019 8:17 AM UTC
Hi @mukhtar_gf,
By selecting an attribute via a dropdown, are you referring to Attribute Domains in ArcGIS? If so, as far as I'm aware, you can only use these in File and Enterprise Geodatabases. Someone correct me if I'm wrong, but a shapefile doesn't have the ability to handle domain values.
gio
Forum|alt.badge.img+15
  • Oct 11, 2019 10:25 AM UTC
@mukhtar_gf
AS @sipsysigh says, geodatabase functionality.
  • Oct 11, 2019 10:55 AM UTC
Sorry...Yes..it is GDB and still not able to see it there in feature class @sipsysigh @gio
sipsysigh
  • Oct 11, 2019 12:08 PM UTC
There is a nice tutorial on domains here:
https://knowledge.safe.com/articles/22897/working-with-geodatabase-domains.html
Hope this helps
Si
