doubt about fme parameters
  • July 31, 2014
  • 0 views
Hi, i  have one fme flowchart and, in that flux, i have a lot of repeated transformers . So, the problem is: is there a way of change the parameter of all transformer at the same time, or i have to change one by one? Thanks !
gio
Forum|alt.badge.img+15
  • July 31, 2014
You can change the parameters (i suspect u are talkning about variables/attributes) to public parameters. That way u only have to set them in the navigator.
