Does FME Desktop 2017 support a CKAN writer? Looking for a way to automate the publishing of flat files to CKAN Open Data Portal
Best answer by fmelizard
Hi @tderosa, at this moment we do not support a CKAN Writer. You can up-vote it on our Ideas page: CKAN.
fmelizard
Forum|alt.badge.img+18
  • August 1, 2017
danilo_fme
Forum|alt.badge.img+45
  • August 1, 2017
Hi @tderosa, i checked this link about API to CKAN API CKAN, and i saw that he works Geo Json.
I think you can generate Geo Json with FME Desktop and publish in CKAN.
Thanks,
adriano
  • August 18, 2017
@tderosa I believe you can use the HTTPCaller transformer to write to CKAN leveraging the CKAN Data API. Another method if you can code in python is to use the python caller to write to the ckan datastore using the CKAN Data API. Of course this will take more time to implement then if there was a CKAN writer but it should still be possible.
