Documentation about the writer's behavior when Truncate Table is "Yes" but no feature is written?
  • Oct 6, 2017 3:28 PM UTC
  • 128 views
Hi! I am using a writer to write to a non-version ESRI SDE feature class. For now I pass some parameter to the "Truncate Table" of the writer. When the parameter is "Yes", the writer deletes everything in the feature class before writing new records, as expected.
When I tried a situation that the parameter is "Yes" but there is no feature to be written, the feature class is not going to be truncated. This is the behavior I want. However, I couldn't find any documentation about this scenario.
Is there any documentation I can use to verify my implementation is ok? I am trying to avoid using undocumented feature as much as possible.
Thank you!
  • Oct 6, 2017 3:42 PM UTC
You are correct, if no feature enters the writer then the table will not be truncated (or dropped, if you activate that).
  • Oct 6, 2017 4:35 PM UTC
Yes, this is the result from my experiment, and I want to use the fact in the FME workspace I am development. This is why I am looking for some documentation (help file) that tells (or implies) this, such that I can make sure the workspace is not using some undocumented functionality that can cause big consequence once the functionality no long present.
fmelizard
Forum|alt.badge.img+22
  • Oct 6, 2017 10:53 PM UTC
Hi @sui_huang, check out the documentation for the Geodatabase Writer. If you scroll down to the GEODB_TRUNCATE_TABLE, you'll see there is a note saying that a feature must reach the Writer for this parameter to be valid.
  • Oct 6, 2017 10:55 PM UTC
Nice, thank you @TiaAtSafe
