Document a workspace
  • Sep 22, 2020 8:55 AM UTC
  • 87 views
fme_hans
Is there a way to automatically document a workspace by reading the bookmarks, for example? .
A workspace uses notations and bookmarks. I would like to export this to a separate document so that some sort of description of the data stream is created.
Greatings
Forum|alt.badge.img+63
In theory, yes, if you set up the bookmarks in a consistent way. You can use a Workspace reader to read the .fmw file and extract certain elements from it, such as the bookmarks. If I recall correctly @Lars de Vries​ has been working on something like that.
fme_hans
  • Oct 2, 2020 8:14 AM UTC
Ok, thanks, i will try the fmw reader.
