Defining a published parameter with an "Advanced Browser" option
  • Nov 6, 2014 2:37 PM UTC
  • 60 views
I want to create a published parameter that prompts on run-time, the user to open multiple files.  I have tried to set the Type to "Filename (Existing)" and the configuration as in the image below.  But this only allows the user to select one file at a time, rather than multiple files.  Is there a way to create the parameter so the "Advanced Browser" option can be enabled?
Thanks,
  • Nov 6, 2014 3:47 PM UTC
A trick.
Add a file-based format reader temporarily.
Link a transformer parameter to the source dataset parameter of the reader.
Delete the temporary reader.
Takashi
  • Nov 6, 2014 3:54 PM UTC
Thanks Takashi, that worked perfectly!
  • Feb 4, 2015 3:23 PM UTC
Also, I would like to do something similar, but this time add an Oracle Table as a Published Parameter.  Is there a way to do this?  Thanks
