Database connection confiurations
  • Nov 26, 2012 2:44 PM UTC
  • 50 views
chris_m
Participant
I was wondering I do a lot of ad hoc workbenches to various databases and geodatabases.  Is it currently possible (if not I would like to suggest it as an improvement) save the conection properities for teh databases I frequently.  This would be a huge time saver and save on problems with typos.
Hi Chris,
when you connect to a database (e.g. ArcSDE) you have to fill in the connection parameters. At the bottom of this dialogue you can click on 'default' and then choose the option 'Safe as My Defaults'. This saves your parameters.
Best regard,
Stefan
chris_m
Participant
  • Participant
  • Nov 26, 2012 3:22 PM UTC
I was aware of that but I am looking so save several different database connections, not justa single configurations.
sigtill
Forum|alt.badge.img+25
  • Nov 26, 2012 7:33 PM UTC
I guess an option would be to save all parameters in a database (or a *.csv-file).
Perhaps like this:
FMEName,mydatabase, username,password
Myfirstdatabase,localhost,myuser,password
Anotherdatabase,192.168.1.1,anyuser,aslkdjf
Then you can use a parameter in the workspace that lets the user select the first column (FMEName).
Then a Python-Startupscript can read the CSV-file and set the corresponding attributes in the workspace to the correct values.
The bad thing is if this CSV-file gets lost - it will be easy to "break in". However for testing this might be good enough.
  • Nov 28, 2012 1:42 AM UTC
I have a similar question. Is there a way to store the connection parameters once for a particular database, so I can reference it in all future ETLs? The DBAs change passwords on a regular basis, and I don't want to have to change all of my ETLs each time that occurs. Any best practices for reader / writer management?
