I'm trying to create a series of attributes based on values of other attributes (I have some FieldName/FieldAttribute combos that I want to turn into attributes on the feature). When I create an attribute called @Value(FieldName), anything I output to the Data Inspector won't show. It just shows ? row(s) and doesn't load anything. Is this a bug or am I missing something?
Best Answer
Data Inspector won't show data when I have an attribute from @Value
Best answer by ciarab
@jakethepainteryes you are right its an Inspector bug in 2016.1, where attributes are not displayed properly in the inspector but the issue has been fixed in FME 2017.
The workaround is
1) Add a Logger and inspect the attributes in the log.
2) Run with Full Inspection and either double click on the feature count after the transformer, or right-click on the feature count and select Inspect features, to view the attributes in Data Inspector.
