Custome transformer - Overriding attribute doesn't work every time
  • Sep 26, 2019 8:04 AM UTC
  • 7 replies
  • 100 views
arthur_bazin
Forum|alt.badge.img+19
Hello,
I have a problem with my FME script.
My goal is to create a custom transformer that does the same thing as AttributeValueMapper but by using a dynamic list off matching value.
Why ? Because I have a file witch contain data that I need to clean :
File "data"
field_test_1
field_2
field_test_2
xxx
Good morning
ab
xxx
Hello
ac
xxx
Salut
ab
zzz
Bonjour
ab
yyy
Konishiwa
ac
To do this, I have a file which contain all my matching values like this :
File "code_list"
code
value
CODE_A_01
value xxx
CODE_A_02
value yyy
CODE_A_03
value zzz
CODE_B_01
value ab
CODE_B_02
value ac
CODE_C_01
value xxx
My goal is to replace value in "field_test_1" and "field_test_2" from the file "data" by codes listed in the file "code list".
Little things to keed in mind : codes need to be filtered as values from differents fields can be the same but not corresponding to the same code (has you can see lines 1 and 6 from file "code_list").
First try :
I've used TestFilter + FeatureJoiner + AttributeManager to replace values in my fields : It work as expected but it fill my script with lot's of transformers.
Second try :
I've created a custom transformer to achieve my goal but I have some trouble with it :
Here is published parameters of the transformer :
Here is what you can find inside my transformer :
I get the value of the fields I need, filter codes, perform a join, set the value for the input data field and then removed every field that I didn't need including fields from the "code list" file (with regex).
When I run my script whit one occurence, it works perfectly.
But when I put a second occurence of this custom transformer like this :
Data in "field_test_2" are <missing> and I don't know exactly why.
Bonus : If the tested field contain a space, inside fields aren't removed :
I put the script and the files as attachments if you want to give a try.
Thank you for your help.
Arthur Bazin
Forum|alt.badge.img+54
  • Sep 26, 2019 12:46 PM UTC
I suspect there is some conflict between the parameters
gio
Forum|alt.badge.img+15
  • Sep 26, 2019 2:16 PM UTC
@savoierider
After the first instancxe of the transformer, the inputs are not available
You can prevent that by making your customtransform generic. It looks generic, but it is not.
I found that doing following helped alleviate the problem in my generic custom transformers:
This is from my generic stringsearcher and remover (it removes a strings from targetstring)
The attribute creator @Value(@Value() does not work if you do it directly on the parameter! (i tried..of course)
You must fetch the parameter into attributes. It now contains the name of the (input) attribute.
To get the value, the second @Value is required. You have to type it after chosing the attribute and entering the texteditor!
Now you should not have the parameter confusion.
I tried it on your attributemanager2 in fme 2019:
It works, the input data is now passed.
I admit, this to be like a hidden mystery, and wonder if @safe should, like, fix it?
Greets!
gio
  • Sep 26, 2019 2:38 PM UTC
..also you might reconsider using the parameter (its value i assume to get the target-attributename) as output.
I refer to attributes for that, leaving the parameter.
arthur_bazin
  • Sep 26, 2019 3:38 PM UTC
Hi @gio,
Thank's for your answer.
One more time, I missed the ParameterFetcher... Thank you for your solution.
I'v tried and it solves the problem with spaced field.
Unfortunatly, I keep the <missing> fields when I use the second occurance of the transformer.
Here is the new configuration :
I fetch my parameters into new attributes : "_param_input_XXX" then I set the value of the field mentionned in the param to the attribute "_input_XXX".
But it didn't resolve the first problem.
Any other idea ?
Here is the new version of the script : DynamicValueMapper_v2.zip
Thank you
Best regards
gio
  • Sep 26, 2019 10:19 PM UTC
@savoierider
I made a working custom.
I failed to do the parameter2attribute thing using a attributemanager. But it works when using a attributecreator. Also coulld not get past the featurejoiner so i used a featuremerger.
By exporting the custom (which i later embedded) the attributes pass.
The Liste now passes through (tidier)
(only thing is, i have not manage to split the attributes at the result though)
This one runs 3 instances:
DynamicValueMapper_G.fmw
tt.fmx
arthur_bazin
  • Sep 27, 2019 7:04 AM UTC
@savoierider
tt.fmx
Hi @gio,
Ok, you definitively put me on the way of the solution. :-)
In fact, the feature joiner doesn't work for generic transformer. You need to use FeatureMerger.
In my second script, you just have to replace FeatureJoiner by FeatureMerger and it works...
So, if I sum up the solution :
If you want to create a generic transformer, you need :
  • To use ParameterFetcher to get the value of parameters associated with features and then using it for naming attributes.
  • To use FeatureMerger if you want to perform joins.
Thank's for the time you spend on my problem, I'll make more try with other transformers next time.
It seems that FME have some trouble with some transformers (or maybe I don't understand the hole logic behind some transformers :-)
Have a nice day.
Arthur Bazin
gio
  • Sep 27, 2019 11:58 AM UTC
@savoierider
In fme 2018 it is possible to use the featurejoiner as well as the atributemanager.
I just added them in the dynamicvaluemapper-g.fmw
using FME(R) 2018.0.0.2 (20180414 - Build 18301 - WIN64)
and it still does its job.
So maybe in fme 2019 version something went awry?
(I dislike the fme2019 interface anyways...;))
