Custom transformers and some 32/64 bit woes
  • Jun 21, 2016 10:12 AM UTC
  • 8 replies
  • 132 views
lifalin2016
Forum|alt.badge.img+42
Last week I built a couple of custom transformers (with Python) in my 64 bit FME. They worked.
Friday I installed PyCharm, which is 32 bit, so I ended up having to install the 32 bit version of FME as well, but finally got it to work there.
Today I'm revisiting my custom transformers in my 64 bit FME, and now they don't work! And they don't work in the 32 bit version neither!!
The error is the "import" statement, that tries to load my custom transformer (import StationingCalculator). The PY/PYC files are present in the FME/transformers folder.
It looks like the whole Python setup is riddled with 32-vs-64 bit issues, so I have to ask, How do I get a stable environment to work with ?
I would prefer to use the 64 bit FME, but also PyCharm, so what the right way to approach this ?
Cheers
Lars
Best answer by david_r
Have you set a custom Python interpreter in FME, by any chance?
If so, you will likely need to set the PYTHON_HOME environment variable so that FME finds the correct Python installation (32 vs 64 bits).
Some more info on the enviroment variables here: http://www.developerzen.com/2010/09/23/the-complete-guide-to-setting-up-python-development-environment-on-windows/
  • Jun 21, 2016 10:21 AM UTC
lifalin2016
  • Jun 21, 2016 12:16 PM UTC
Hi David,
How do I even do that ? I was under the impression that FME used its own internal Python interpreter. Here's the log file part for my error:
Loaded module 'Python_func' from file 'C:\\Program Files\\FME 2016\\plugins/Python_func.dll'
FME API version of module 'Python_func' matches current internal version (3.8 20160224)
Using FME's provided Python interpreter from `C:\\Program Files\\FME 2016\\fmepython27\\python27.dll'
Python version 2.7 loaded successfully
Adding folder `C:\\Program Files\\FME 2016\\transformers\\' to the python path
Python Exception <SyntaxError>: invalid syntax (StationingVisitor.py, line 142)
Error executing string `import StationingCalculator'
I don't have a PYTHON_HOME env. variable, but I needed to add a PYTHONPATH, a FME_PYTHON_PATH, and an FME_DEV_HOME to make PyCharm work. The references to FME in these had to be to the 32 bit version before it would work.
The issue is, that these settings are singular, and I'm not sure which are used for what.
I did copy all my transformer files in the 64 bit folder to the similar folder in 32 bit, but something is still amiss.
I'll have a look at the link you sent.
Cheers
Lars
lifalin2016
  • Jun 21, 2016 12:32 PM UTC
Hi again,
I tried adding the FME_PYTHON_PATH (which I disabled above), but it made no difference:
Adding folder `C:\\Program Files\\FME 2016\\fmeobjects\\python27' to the python path
Adding folder `C:\\Program Files\\FME 2016' to the python path
@Python failed to execute command string `import StationingCalculator'
@Python execution failed
Cheers
Lars
lifalin2016
  • Jun 21, 2016 12:42 PM UTC
It suddenly occurs to me, that I don't have the 'import StationingCalculator' anywhere in my code. I assume it's some kind of FME wrapper that fails, suggesting some error in my code. I'll be back after checking that.
lifalin2016
  • Jun 21, 2016 1:01 PM UTC
Hi David,
It was indeed an error (a single missing ":") that was the cause. Hrmpf. I recompiled all my PY files manually, and that revealed the error. Note to self: Do that before freaking out in the future. Wish to Safe: Make a better error message, suggesting a compilation fault as the culprit (as it's FME that initiates the compilation).
I checked whether PyCharm still worked. It does! I had a struggle last week to get it to import the fmeobjects namespace when running programs, now it just works without hiccups, and all my paths currently point to FME 64 bit . Strange! I'll try and reboot my machine to see if it's something cached.
I'm still interested in any "best practice" of having a stable Python development environment, regardless of whether it's inside FME or externally edited and run in PyCharm or something else.
Cheers
Lars
  • Jun 21, 2016 1:14 PM UTC
Hi David,
Cheers
Lars
Good to hear you found the error.
Have you seen this article? https://knowledge.safe.com/articles/726/use-pycharm-as-fmeobjects-python-ide.html
lifalin2016
  • Jun 22, 2016 7:25 AM UTC
Yes, I've been using that to setup PyCharm in the first place. The problem is that it doesn't address any 32/64 bit issues and problems.
lifalin2016
  • Jun 22, 2016 8:28 AM UTC
It was actually this line in the FMX that failed:
DYNAMIC_FUNCTION_CONFIGURATION Python import StationingCalculator
