Custom transformer to evaluate custom function on dynamic set of attributes
  • September 12, 2016
  • 35 views
Hi
I have a workflow where we are calling a custom arithmetic function (DoubleAsRaw64) to generate a new attribute value based on the old value - this happen in 20+ workplaces on many different attributes.
We currently do this by using the AttributeManager and:
1) Checking if the attribute value has a value
2) If it has a value then we do @Evaluate(@DoubleAsRaw64(@Value(NameOfAttribute)))
I would like to encapsulate this in an custom transformer where I would just have to check of the Attributes on a list - and the the transformer will then apply the DoubleAsRaw64 function on those attributes. This would create a cleaner workplace and minimize the risk for typo etc.
I have tried to create a super simple custom transformer with one Attribute List as a published parameter Attributes_to_Raw64.
And a single ExpressionEvaluator set to overwrite the attributes in $(Attributes_to_Raw64)
the Arithmetic Expression is @Evaluate(@DoubleAsRaw64(@CurrentAttribute()))
This works if I have a single attribute selected in Attributes_to_Raw64 - but as soon as I select more attributes the transformer fails.
So my questions are:
1) How are I implement this so it works with more than one attribute selected to be evaluated per feature?
2) How do I best implement a quick null check?
3) How do I do this in an efficient way (as there will be millions of features passing though this).
I would be grateful for any pointers! :)
Thank you!
Custom Transformer:
  • September 13, 2016
Hi @malteohlers, it doesn't seem that you can pass multiple attribute names to the "Attributes to Overwrite" parameter of the ExpressionEvaluator within a custom transformer through its published parameter. It might be a limitation of the current FME, seems we have to wait for a relevant enhancement unfortunately. Please contact Safe support.
A workaround I can think of is to perform the arithmetic operation with a Python script.
  1. Add an "Attribute List (comma delimited)" type parameter to the custom transformer.
  2. Save the parameter value (comma-separated attribute names) into a temporary attribute. e.g. "_attrlist", with a ParameterFetcher.
  3. Use a PythonCaller to perform the operation for each attribute. The script looks like this.
def processFeature(feature):
    for attr in feature.getAttribute('_attrlist').split(','):
        isNull, isMissing, _ = feature.getAttributeNullMissingAndType(attr)
        if isNull:
            <do something if the attribute is null>
        elif isMissing:
            <do something if the attribute is missing>
        else:
            try:
                oldValue = float(feature.getAttribute(attr))
                newValue = <calculate new value based on the old value>
                feature.setAttribute(attr, newValue) # overwrite
            except:
                <do something if an error occurred>
If you need to use the @DoubleAsRaw64 function to get the new value, maybe the "FMEFeature.performFunction" method can be used to call the function, but I'm not sure if it works fine since I don't know its specification.
Note that this method will fail when a specified attribute name contains a comma. If an attribute name could contain commas, it might be difficult to resolve this with a Python script. In such a case, "Attribute List (space delimited)" type parameter and a Tcl script may be another alternative.
mark2atsafe
Forum|alt.badge.img+59
        if isNull:
        elif isMissing:
        else:
            try:
            except:
Yes, I can confirm that action fails - both inside and outside a custom transformer. I'll file a problem report with the developers and let you know when it is fixed.
mark2atsafe
        if isNull:
        elif isMissing:
        else:
            try:
            except:
Filed as PR#72231
