Custom Transformer "ArcGISDissolver"
  • Jan 22, 2018 11:31 AM UTC
  • 42 views
I have dataset which consists of about 40 millions parcels. Some of them have the same identifier and I would like to join them into one area (with dissolve lines). I would like to use custom transformer which is very similar to https://knowledge.safe.com/articles/47216/using-arcpy-for-fme-feature-processing.html. I have FeatureWriter, PythonCaller and FeatureReader Transformer and I have a problem with keeping attributes after FeatureWriter transformer because in the PythonCaller Transformer I would like to use Attribute Accumulation (…”AREA SUM; CITY FIRST; POSTCODE FIRST; COUNTRY FIRST”…). I will need these information as a final score. Maybe is here someonebody who could help me?
  • Feb 27, 2018 3:34 PM UTC
Got the right format, Just change the last bit of the python code from :
arcpy.Dissolve_management(inFeatures, outFeatureClass, dissolveFields, "", "MULTI_PART", "DISSOLVE_LINES")
to
arcpy.Dissolve_management(inFeatures, outFeatureClass, dissolveFields, "AREA SUM; CITY FIRST; POSTCODE FIRST; COUNTRY FIRST", "MULTI_PART", "DISSOLVE_LINES")
as shown in:
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/dissolve.htm
