Creating an attribute that accumulates count of duplicate values (sequentially)
  • September 26, 2024
  • 10 replies
  • 147 views
salvaleonrp
Forum|alt.badge.img+16
I was able to do a cumulative count of duplicate values (where duplicate is “-1” only) using a Group By on a Counter transformer shown below.
(Added note: I should have added this to remove ambiguity - SORRY. The output as shown below in the Preview is the desired output. I only care to know the number of consecutive sequential values when the value is “-1”. If the pattern changes and another series of duplicate “-1” appears, the count starts with “1” again. I don’t care if the pattern for duplicate values are greater than “0”, like “2420” on the Preview.)
Since I have more than a dozen of these attributes, I’d like to use an AttributeCreator instead but I can’t seem to use the CurrentAttribute() to accumulate duplicate values.
In addition, everytime a sequence of “-1”s begin (as shown in row 143 above), count starts at 1 again.
Any suggestions?
Best answer by hkingsbury
You can use a AttributeCreator with Adjacent Features enabled
Then use a conditional statement to check if the previous features value equals the same as the current feature. Then the value will be the previous features count plus one if they’re the same. If the are not the same, set the count value to one
The one down side of this approach, is that FME thinks the count attribute doesn’t exist (it kinda does/doesn’t).
To fix this, you can put an AttributeExposer in front of the AttributeCreator to expose the attribute
todd_davis
Forum|alt.badge.img+22
The error you are getting with the counter restarting is due to your setting “When Group changes”. It needs to be “when all features received” because you groups are not in order. E.g. -1 is one of the first groups, then a new group of 2420 arrives, and then a “new group” or -1 arrives.
That is the first bit, I’ll have a think about the second. I do already have a quicker way, but like you say “dozen of attributes”, so there has to be a better way than my initial thought.
todd_davis
Actually, this should be the same logic used in the GroupCounter transformer. That would be a relatively tidy way of implementing this. I am also assuming that the data is not huge (e.g. not millions or billions of features), as if was, then this would be far better as a pointcloud analysis.
Not knowing the reasons for this, I have started to wonder if you are wanting to get the maximum count of each group. If this was the case, then the statisticscalculator would be better.
liamfez
Forum|alt.badge.img+36
I was thinking the same, that perhaps the statisticscalculator may do what is desired.
hkingsbury
Forum|alt.badge.img+55
Are you able to share some example data?
salvaleonrp
Explained in my added notes that the Table preview is the desired outcome.
salvaleonrp
Explained in my Added Notes that the Table preview shows the desired outcome. Really looking for an alternate solution using AttributeCreator that will produce the same result as the Counter for many attributes.
salvaleonrp
Here’s the sample data. There is no need to sort the TestDate.
hkingsbury
todd_davis
Like this??
This might not be exactly what you want, but I believe you can achieve what you want with adjacent features in attributecreator or attributemanager
salvaleonrp
I tried this approach orginally but I was comparing attribute values (cached) instead of the attribute.
The Incomplete Transformer for feature[-1].count is an issue I’ve reported before. Good reminder for me to check on that issue.
Thanks to all responses.
