Create directory with Python
  • Aug 20, 2013 9:00 AM UTC
  • 7 replies
  • 108 views
farfar
Forum|alt.badge.img+12
I create a fmw that : 1. create a directoy with the same name of zip file, 2. move the zip file to this directory.
this fmw works fine withe if the name of file is note a numeric (like : toto.shp.zip, => OK but with another file that has only numeric name : 1.shp.zip => KO).
With FME Desktop it works fine for both cases.
If i run it with FME SERVER, there is an error :
54 WARN 0.2 1.3 2013-08-20 10:49:50 Python Exception : [Errno 2] No such file or directory: '\\\\\\\\1.shp.zip' 55 ERROR 0 1.3 2013-08-20 10:49:50 Error encountered while calling function `processFeature'
No more details for this error.
Any help?
Thanks an advance.
Farfar
  • Aug 20, 2013 10:07 AM UTC
Hi Farfar,
Path delimiter may cause the error. How about using / (slash) instead of \\ (back slash)?
Takashi
farfar
  • Aug 20, 2013 10:12 AM UTC
Hi Takashi,
I use "join" to have a directory path.
this my python script :
def processFeature(feature):          #create work folder     fmebasename = feature.getAttribute("fme_basename")     workfolder = os.path.join(FME_MacroValues['workFolder'],fmebasename)          if not os.path.exists(workfolder):         os.makedirs(workfolder)     else:         #delete files ito work folder         os.chdir(workfolder)         filelist = glob.glob("*.shp.zip")         for f in filelist:             os.remove(f)          # move zip file into work folder     filename = fmebasename+".shp.zip"          fmedataset =  feature.getAttribute("fme_dataset")                end = fmedataset.find(fmebasename)        src_file = fmedataset[0:end]              src_file = os.path.join(src_file, filename)          dst_file = os.path.join(workfolder, filename)     shutil.move(src_file, dst_file)              pass
Thanks
Farfar
farfar
  • Aug 20, 2013 12:29 PM UTC
I use my script in my previous message, i replace  :
by :
workfolder = FME_MacroValues['workFolder'] + "\\\\" + fmebasename.
And i still have the problem.
Any Help?
Thanks.
Farfar
  • Aug 20, 2013 1:17 PM UTC
Was a slash "/" also ineffectual?
Takashi
farfar
  • Aug 20, 2013 1:22 PM UTC
Hi Takasha,
I tested both of "//" ,  "\\\\" and "join" function and i've a same error. But if i use a non numeric file name, it works.
Farfar
  • Aug 20, 2013 1:54 PM UTC
the simplest might be to insert
print "src_file:", src_file
or something like that at the end of your script. This  will print to the FME log window the actual values generated by your script. Let us know what it says so that we can try and help you find the error.
David
farfar
  • Aug 20, 2013 3:15 PM UTC
Hi David,
Thank you for your idea. The pb is the extract the value of "src_file" : the fme_dataset has a value that is in the path, so to split the path, its wrong.
Example :
   print "fmebasename:", fmebasename
    print "fmedataset :",fmedataset      end = fmedataset.find(fmebasename)        print "fmedataset:",fmedataset     print "end:",end     src_file = fmedataset[0:end]
The result is :
  fmebasename = 1
  fmedataset : \\\\\\\\1.shp.zip\\1.shp
  end:,2                  ==> WRONG
  src_file: \\\\1.shp.zip
I find now the origin of my error and fix it.
Thank you
Farfar
