Create attribute in loop with counter number in its name
  • Nov 7, 2018 1:57 PM UTC
  • 9 replies
  • 260 views
jeroen
Forum|alt.badge.img+15
I'm trying to create multiple attributes during a loop depending on the amount X. If x = 3 the attributes created should be Foto_doc,Foto_doc2 and Foto_doc3.
I have a working flow with loop in the below example but the attribute creator does not work correctly with the @value(attribute_name) option. Is there something missing in this flow or is it not possible to use attribute values for naming attributes during a loop?
Best answer by jdh
Dynamically named attributes cannot be automatically exposed on the canvas and used by other transformers.
You can write them to a format if you use the SchemaSetter custom transformer and a writer set to Dynamic Schema Definition.
Personally I wouldn't use a loop at all, just a Cloner set to Max_Images, and build the attribute name from the _copynum attribute. This would also avoid the formatting issues of 2.0, 3.0, though that could be taken care of using the StringFormatter.
  • Nov 7, 2018 2:25 PM UTC
The image and the workspace you have posted cannot be accessed for some reason. Could you please make sure that those have been uploaded correctly?
jeroen
  • Nov 7, 2018 2:33 PM UTC
This should work now. Do not know what the problem was but i re-uploaded the file.
jeroen
  • Nov 7, 2018 2:35 PM UTC
Corrected the x = 2 into x = 3 to match the named outcome correctly.
jdh
Forum|alt.badge.img+41
  • Nov 7, 2018 3:00 PM UTC
Like Takashi I cannot access your workspace, but in situations where @Value(attribute_name) hasn't worked in the past (double check that it's a capital V), I've had success with FMEFunctionCaller using the @SupplyAttributes(attrName,attrValue) function.
jeroen
  • Nov 7, 2018 3:22 PM UTC
reuploaded the file. Also the image was missing now... hope it works now or it could be that the forum has a hard time.
Forum|alt.badge.img+54
  • Nov 7, 2018 3:27 PM UTC
It doesn't look like you are exposing the new attribute names?
jeroen
  • Nov 7, 2018 3:37 PM UTC
Thanks! Forgot that attributes could be hidden. The attribute exposer does not allow a value from attribute as input. But with manual inspection in the data inspector I can now see that the attributes are created but not showed in the endresult. Also the format is not what i would like.
Also: to solve the 2.0,3.0 I used @Evaluate(@round(@add(@Value(loopCounter),1),0))
jdh
  • Nov 7, 2018 3:48 PM UTC
jeroen
  • Nov 7, 2018 4:02 PM UTC
Schemasetter did the trick.
For the formatting: @Evaluate(@round(@add(@Value(loopCounter),1),0))
