Copying attribute values - how to set a default value in the output if blanks/nulls in the source?
  • November 7, 2016
  • 7 replies
  • 158 views
fmelizard
Forum|alt.badge.img+18
I need something like this: if the value is NULL or non-existent, then name field as "UNKNOW", else where bring the values assigned to it.
How can I tell FME to separate the NULL and empty cells from the numbered ones?
For example:
feature 1 has attribute ‘someattr’ == blank, then attribute ‘someoutput’ = UNKNOW
feature 2 has attribute ‘someattr’ with a value, then attribute ‘someoutput’ = the value from ‘someattr’ attribute
fmelizard
  • November 7, 2016
See this workspace for an example:
attributevaluemapper.fmw
Screenshot:
erik_jan
  • November 7, 2016
Have a look at the NullAttributeMapper. That transformer seems to fit the description.
NullAttributeMapper
itay
Forum|alt.badge.img+17
  • November 7, 2016
The AttributeManager can also be used for this if else kind of statements and the attribute mapping.
fmelizard
  • November 8, 2016
Screenshot:
Here is a screenshot showing settings to update a TYPE attribute. In this case the source TYPE attribute has some single space values ' ', which need to be replaced with text 'UNKNOW'.
https://www.dropbox.com/s/izo4hin9o1c0hz2/Screenshot%202016-11-08%2000.15.30.png?dl=0
mark2atsafe
Forum|alt.badge.img+44
  • November 8, 2016
That's what I was thinking. Set it up to create 'someoutput' using the conditional option, with the condition being the value of 'someattr'
erik_jan
  • November 8, 2016
NullAttributeMapper
Reading the question again: First copy 'someattr' in 'someoutput' and then use the NullAttributeMapper on 'someoutput'.
gio
Forum|alt.badge.img+15
  • November 8, 2016
if the attribute exists u can also simply use a creator for this.
@SomeAttr == ""?"Empty":@SomeAttr
if misses or Null it results in a missing operand error.
