Coordinate systems are not available in FME Flow
  • January 23, 2025
  • 63 views
n.d
Forum|alt.badge.img+7
Hi everyone,
I have a question about the Reprojector.
In the reprojector in FME Form, my desired coordintion systems are available:
But when I publish it to FME Flow, some of the coordinate systems are not available to select from:
Could you please help me to solve the problem?
Thanks!
saraatsafe
Forum|alt.badge.img+12
  • January 28, 2025
Hi ​@n.d, I can’t seem to recreate your issue and was able to see all the coordinate systems after publishing to FME Flow 2024.2. Would you be able to let me know what version of FME Form and Flow you’re using? What Flow Service(s) are you publishing to (Data Download, Job Submitter, etc)?
n.d
  • January 29, 2025
Hello Sara,
FME Form version: 2024.0.1.0
FME Flow version: 2024.0.1
And I am publishing to Data Download.
Thanks for your support.
saraatsafe
  • January 30, 2025
Hi ​@n.d, did you originally make this workspace in an older version of FME Form? Sometimes User Parameters might lag when being published up into Flow, and moving to a new version might cause some weird behaviour too.
Have you tried republishing your workspace from scratch? Alternatively, if you’re able to upgrade Form and Flow I’d suggest giving that a try too.
