Convert Month text to number
  • Jul 10, 2017 2:14 PM UTC
  • 208 views
simonhume
Forum|alt.badge.img+7
Hi
I have a simple spreadsheet that has a month column in text ie January, February.
How do i convert this to a number? So for January it would be 01, February 02 etc etc.
I've tried using AttributeValueMapper with the following source value;
@Value(Month)='January'
and a destination value of 01
but no luck.
Would be grateful if someone could suggest how i can do this
thanks
Simon Hume
Best answer by jdh
The AttributeValueMapper should work. Case matters.
jdh
Forum|alt.badge.img+41
  • Jul 10, 2017 2:18 PM UTC
simonhume
  • Jul 11, 2017 7:44 AM UTC
Thanks very much for you help, has worked a treat#
regards
Simon Hume
  • Jul 11, 2017 12:34 PM UTC
Just for your information. The StringPairReplacer could also be uses here. And, I found this expression works fine in FME 2017.1 beta. FME 2017.1 coming soon!
@DateTimeFormat(@DateTimeParse(@Value(month)012017,%B%d%Y),%m)
