Convert datestamp values to friendly UK date format
scarter
Forum|alt.badge.img+10
I have a geojson including an attribute with datestamp values. An example value is 202410231836 (year, month, date, hours, minutes - yyyy mm dd hh mm). These are important as I’m running testFilters with it.
However I would also like to create a parallel attribute showing an easy to read UK date value from it. So, 202410231836 would convert to ‘31/10/2024 18:36’.
I’ve been looking at DateTimeConverter transformer but couldn't work out what import format to use and what output format to pick - assuing that DateTimeConverter is the one to use.
Any advice would be appreciated.
Thanks,
Stuart
andrewj74
  • June 13, 2024
if you leave the input format blank it should autodetect that? if not use the quick guide reference at the bottom to construct it
mark2atsafe
Forum|alt.badge.img+48
It will only autodetect the FME format or ISO formats. But this one is pretty straightforward. It looks like %Y%m%%d%H%M for input and %d/%m/%Y %H:%M for output.
scarter
  • June 17, 2024
Thanks for that @mark2atsafe .
I’ve tried that, assuming that I use End_date and Start_date as the ‘Datetime_attributes’…
But I get this result…
Thanks,
Stuart
andrewj74
  • June 17, 2024
Thanks,
Stuart
looks like there is an extra % in the input?
%Y%m%%d%H%M  - %Y%m%d%H%M
scarter
  • June 17, 2024
Hi @mark2atsafe . That is resolved now. Thanks.
